Question BenQ w1070 placement
soundsgooodtome
Established Member
I was thinking of putting my benq pj in a cabinet as the table it was on keeps getting knocked by me dogs and kids, it has room around it so seems to be airy,would this be safe ?
reevesy
I used to have one of these but had mounted on a high shelf.......can't quite remember but don't some PJs shut down ..or bring up temp warnings if they get too hot
you'll probably better off asking in the projector section
Looks to be front vented so shouldn't be a problem I would have thought
soundsgooodtome
Established Member
yep you are right been going for a few weeks now and doesn't get any hotter than being on top of a table, nest thing is how much quieter it is,John
manka
Established Member
my projector sits in a shell box mounted into the wall but I bring it out in a sliding shelf when I want to use it. always an option if you were concerned, you'd obvs need to modify your cabinet!
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
