Benq w1070 irregular fan noise
Discussion in 'Projectors, Screens & Video Processors' started by lambooni, Mar 4, 2013.
  1. lambooni
    lambooni
    Feb 14, 2013
    12
    Hello,
    I have had my Benq w1070 for a couple of weeks now. I have just ceiling mounted in a few days ago and since then can now hear an irregular fan noise, like a brum... brum... brum... (It may well of been there before, just didn't notice it). It is not particularly loud and only really hear it when the film is quiet but its quite annoying! Has anyone else found this or do I have a problem with my projector?
    Like I say its no louder than I would expect but I would expect the fan to keep more of a constant hum.
    Thank you,
    Adam
  2. lambooni
    lambooni
    Feb 14, 2013
    12
    looks like this may be a bit of a common issue. found this on youtube
    BenQ W1070 Fan Noise
    edit: sorry realised the video is not very good (cant really hear anything!) but the video comments are the bit i was referring to.
  3. vinnymcd100
    vinnymcd100
    Jul 8, 2012
    656
    Dunngannon
    +40
    I took delivery of mine today and have it ceiling mounted. Its very quiet with no fan noise at all. Have you got the high altitude mode on? This increases fan noise......might be worth trying.
  4. lambooni
    lambooni
    Feb 14, 2013
    12
    mine was also very quiet to start with... it seems to have got a lot louder over the last two weeks. high altitude is off, thanks for the suggestion though.
    Is yours ceiling mounted or on the floor. I dont know if turning it upside down can make it louder or maybe the ceiling is reflecting the noise more...
  5. lambooni
    lambooni
    Feb 14, 2013
    12
    I have put a video on youtube. Any feedback would be much appreciated. I really dont want to have to send it back but im sure this cant be right!
    Cheers, Adam
    [​IMG]
  6. lambooni
    lambooni
    Feb 14, 2013
    12
  7. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    Mine is noisy but the drone is constant, yours sounds like a fan fault to me.
  8. TLMONKEY
    TLMONKEY
    Nov 22, 2010
    387
    +28
    Lookslike one of the 2 Ive got is starting to do the same as yours. Its only got 15 bloody hours on it.
    Is the RS rep still on this site?
