Benq W100 DVI>PC Which resolution?
Discussion in 'Projectors, Screens & Video Processors' started by paulio56, Apr 25, 2007.
  1. paulio56
    paulio56
    Hi all,
    Got myself a Benq W100 today. I'm a little lost as to which resolution to set my desktop to? I will primarily be using it for movies.
    I have a Radeon x1650 connected via DVI to the PJ.
    Lowest res I can set to is 800x600.
    Any help will be much appreciated!
    EDIT: I also need help setting the refresh rate - currently set at 60hz
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,775
    +3,190
    Set a custom resolution if you can at 856 x 480. If you can't, the program Powerstrip can do it for you.
    Another alternative is do what I do now and use 640 x 480 or 800 x 600 and use 16:9 mode. With software such as WinDVD, it displays the correct ratio for you (has a widescreen monitor option).
    60hz should be fine.
