BENQ PB2250 dlp at Amazon £612.98 inc del START DIGGIN'
Discussion in 'Projectors, Screens & Video Processors' started by ButtonUPS, Mar 22, 2006.
  1. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    Saw this on Amazon today just wondered anyones thoughts?
    could not find info on the forums so here is the spec
    Features
    Dimensions (WxDxH): 23.9 cm x 18 cm x 8.6 cm
    Weight: 1.9 kg
    Image Brightness: 2200 ANSI lumens
    Max Resolution: 1024 x 768
    Colour support: 24-bit (16.7 million colours)
    Image Contrast Ratio: 2000:1
    Bulb type: NSH 200 Watt ( 2000 hour(s) )
    Video Input: RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL ) - HDTV, EDTV, SDTV
    Interfaces:
    1 x component video / RGB input -
    15 pin HD D-Sub (HD-15)
    1 x S-video input - 4 PIN mini-DIN
    1 x composite video input - RCA
    1 x USB - 4 PIN USB Type B
    1 x audio line-in - mini-phone stereo 3.5 mm
    4:3 / 16:9 screen selectable
    Think this could be a bargain!/ ?
    bit bright on paper how about that filter that was on the sharp Sharp XV modifications?
    pdf manual http://www.benq.co.uk/ServiceAndSup....96.30/projector/manuals/pb2250/pb2250-en.pdf
  2. Darko
    Darko
    Apr 13, 2005
    4,226
    Caterham on the hill Surrey
    +223
    a great data projector a tad bright for home cinema but I am sure in a conferance room it would do great
    Darko
