BenQ PB 8120 projector
K
kevin9761
i used this projector for around 300hundred hour then ithad to be sent back cos it was playing up i got a full refund so im looking for somting new with a better spec for £1000. can any one recomend any .it neads to be dlp,heres the spec of my old one..
BenQ PB 8120 projector specification
Computer resolution SVGA
Resolutions with compression VGA-XGA
Keystone correction YES
Brightness (ANSI lumens) 1800
Contrast ratio 2000:1
Speakers Yes
Lamp life 2000
PC inputs 1
Video compatibility Yes
Mouse control Yes
Lens zoom Manual
Weight (KG) 3.1
Technology LCD
Wireless No
Application Pubs and clubs
Additional features 1st yr swap Smoke warr.
Warranty (UK) 3 year RTB
thanks guys.
K
kevin9761
ok ive found this one what do you think
Main Features
Product Description BenQ Professional PB8240 - DLP Projector
Device Type DLP Projector
Dimensions (WxDxH) 32 cm x 23.6 cm x 10.6 cm
Weight 3.5 kg
Image Brightness 2500 ANSI lumens
Max Resolution 1024 x 768
Colour support 24-bit (16.7 million colours)
Image Contrast Ratio 2000:1
Bulb type UHP 200 Watt ( 2000 hour(s) )
Video Input RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL ) , HDTV
Input Device Remote control
Power AC 110/230 V ( 50/60 Hz )
Power Consumption Operational 330 Watt
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
