Benq 5120 + Banding
Discussion in 'Projectors, Screens & Video Processors' started by sniffer66, Mar 29, 2005.
  1. sniffer66
    sniffer66
    May 22, 2004
    9,622
    +3,307
    Have my new 5120 connected to my HTPC via DVI-D. I've used Powerstrip to set my HTPC res at 1:1 (856x480 @50hz) and it looks great
    As an experiment and cos its meant to support up to XGA and HDTV resolution I tried upping the HTPC res to 1024x576 and 1280x720.
    I can get the PJ to detect a signal at 1024x576 but I get shimmering blue vertical banding across the whole screen. The bands are very bright and can be seen more clearly on a dark background. At 1280x720 I cant even get the pj to detect a signal.
    I've logged this out to Benq but had no response yet. Anyone have any ideas why ?
  2. MR.COATES
    MR.COATES
    Mar 25, 2002
    148
    Scotland
    Perhaps they're just really busy?
    :clown:
    Sorry - sadly I can't even try this as I've not got anything to test HDTV pics yet. Odd though, if it supports it then surely it should work.
    I hope that Benq have an answer though - perhaps it's the input source though?
  3. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    I've not plugged a laptop etc. into mine yet so can't comment.
  4. sniffer66
    sniffer66
    May 22, 2004
    9,622
    +3,307
    I remembered last night that I have an old Zinwell scaler knocking around. This will upscale to HD resolutions.
    I connected this via Svideo to my SKY + AND Xcard and sent a 576p and 720p signal to the 5120.
    Both looked fine - although much worse PQ than the HTPC via DVI
    Looks like its a problem with the resolution on the HTPC. May be Powerstrip timings. I'll have to take a look.
    By the way there is world of difference between the PQ of the HTPC and straight Svideo (which I also tested). If you guys can do it I'd strongly reccomend the HTPC route to really make the most of the 5120 :)
  5. JonLeach
    JonLeach
    Sep 17, 2002
    742
    Deepest Darkest Yorkshire
    +22
    Hi Sniffer i'm using the HTPC route and have just got a 5120 last thursday. spent some of the weekend playing and tried powerstrip dont know the software but could not get it to change the output to the native 856x480 res. just 800x600 or 1024x768. it is running 1152x??? though.
    any ideas
    Jon
  6. sniffer66
    sniffer66
    May 22, 2004
    9,622
    +3,307
    Jon
    856x480 is selectable from custom timings. I loaded the default settings of that one in and then made some minor tweaks to get 1:1
    I'm not near my HTPC unfortunately or I could post the timings for you. I'll try later when I get home
  7. JonLeach
    JonLeach
    Sep 17, 2002
    742
    +22
    cheers i'll have a 2nd look when i get home
    Jon
  8. JonLeach
    JonLeach
    Sep 17, 2002
    742
    +22
    tried the native resolution but seen to have a problem with the fonts any chance of you posting the working settings
    Jon
  9. sniffer66
    sniffer66
    May 22, 2004
    9,622
    +3,307
    at work at the mo, whats the problem wiht the fonts ?
