Benefits of Uni-directional Scart Lead?
Discussion in 'Cables & Switches' started by sgbeattie, Jun 21, 2005.
  1. sgbeattie
    sgbeattie
    Jun 1, 2005
    Dear AVForums,
    I read with great interest (Keene Electronics Website) that you can buy a scart lead which is Uni-Directional.
    Keene state that using one to connect a DVD player to a TV reduces ALL possible interference which may be caused by a conventional Scart lead.
    I thought finding a uni-directional scart lead would be easy (Keene sell them),
    but, other AV retailers don't seem to stock them.
    Can anyone help me. Please!
    Steven Beattie
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    cut a couple of pins off a normal fully wired SCART, and you end up with a Uni directional SCART (pin 19 from one end, and pin 20 from the other end).
    This will remove the chance of video loopback, that can show as a double image, or a faint ghost image from another tv channel on your screen. Almost any cheap SCART becomes a top quality SCART if you do this to it.
  3. sgbeattie
    sgbeattie
    Jun 1, 2005
    Dear PJClark,
    Thanks for replying. Which tool should I use to cut the pins?
    Any chance of a pic or diagram showing the pins I need to cut?
    Thank you in advance.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    [​IMG]
    Just repeatedly bend the pins until they break.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    sgbeattie
    There are plenty of Unidirectional SCART cables on the market - most Manufacturers label them as 'RGB Only'.
    Rather than snipping pins/wires they tend to use a Multicore cable with less conductors than a Fully Wired SCART cable and use thicker conductors and better screening so you remove the unwanted effects of a fully wired cable and potentially have less resistance in the cable into the bargain.
    You tend to pay a premium for the RGB Only SCART cables - SUPRA AV6 (RGB Only) and AV6.4(RGB with Stereo Audio) and QED SQUART are two we often use.
    Best regards
    Joe
