Bendy Picture on a 28PW6515 Philips TV
Discussion in 'General TV Discussions Forum' started by The Guru, Dec 31, 2001.
  1. The Guru
    The Guru
    28PW6515 Bendy Picture
    I have just bought one of these TV's and instantly spotted the fishbowl effect especially on the right hand side. Unfortunately I noticed this after I had bought the set. Did you ever get your problems sorted by an engineer and is it worth me getting one called out.
    Also in 4:3 I have curvature at the sides is this a known problem or did you manage to right this aswell.
    Please respond as the issues raised are driving me mad.
    :confused:
  2. Guest
    I've just recently had one of these TV's and yes there is an occasional slight curve on the right-hand side. Left side is perfectly straight. However on my set the problem is not significant enough to warrant an engineer call out. I don't know if they're all like this but mine's really not that bad and I'd go as far to say that I'm really pleased with it.
