Bending flat speaker cables
Discussion in 'Home Cinema Speakers' started by McBain, Aug 4, 2003.
  1. McBain
    McBain
    Feb 15, 2001
    156
    Fair Oak
    All,
    We're getting new carpet fitted, and I thought this might be a good time to lay some speaker cable underneath. Unfortunately we have a solid floor, so I'm thinking of getting some flat cable (maybe the ixos self-adhesive) and running it from where I intend to put my rack to the back of the room for surrounds.
    A couple of questions:
    1) Should I just run it straight across the room, or does walking on it damage it?
    2) How do you go about laying flat speaker cable around corners? Does it bend/twist etc?
    I guess if using flat is going to be tricky I'll have to think of something else.
    Cheers,
    Sam R
    Winchester UK
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    if you put the cable under the underlay there shouldn't be a problem if the areas aren't "heavy traffic" zones but for peace of mind, go round the edge of the room. QED's flat cable that I used for my surrounds can be bent without any problems at all so I guess the IXOS stuff will.
