Bending edge...
Discussion in 'General TV Discussions Forum' started by JohnLin, Jun 12, 2004.
  1. JohnLin
    JohnLin
    Quick question...
    I'm using a Panasonic HDTV CRT at the moment. The leftmost side of the screen has a small issue with bending, however, and causes straight lines to warp a bit. Normally, it isn't an issue, but when using things that feature lots of straight edges it looks odd.
    If I were to modify settings in the service mode (which I am familiar with, but changes I have made did not cause this) what type of thing should I look for? All settings make sense from the standpoint of written text, but I'm not sure how I should go about modifying it.
    Any suggestions?
