Belkin wireless router constantly needs rebooting
Discussion in 'Networking & NAS' started by cjb, Jan 17, 2008.
  1. cjb
    cjb
    Aug 7, 2006
    170
    I have a NTL/Virgin cable broadband modem linked to my PC with cat5 cable and also to a Belkin 54g wireless router, with which I received a Belkin wireless USB adapter. I also have a wireless laptop.
    I have no problem with internet access on any one device at any one time.
    I have no problem using the main PC directly to the internet together with either the Laptop or the adapter on another PC .
    But, if I am already connected to the internet on either of the remote devices, when I try to connect and especially with the laptop, then that connection is unable to be made... until I reset the 54g router.
    The signal level is very good. All PC are running XP.
    I recently saw a message on Virgin saying there were issues with Belkin and to check updates.
    I have checked Belkin site for any updates but there don't seem to be any for the router, there was one for the adapter.
    I have checked the configuration and changed channel. The IP address is on auto .. BUT at one point I did see a message on the laptop saying another user was using the same IP address...
    SO, is this normal... is there a IP connection clash or do I have a device problem ?:rolleyes:
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    I had a Belkin router and it crashed all the time needing it to be rebooted. Like you say it showed up as a very good connection but wouldn't work until rebooted. I have come to the conclusion that Belkin routers aren't very good and I now have a D-Link router which I have had since mid December and suffered no problems
  3. cjb
    cjb
    Aug 7, 2006
    170
    Ok, thats what I was afraid of, especially with the Virgin warning. Which model do you have ?
  4. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
  5. cjb
    cjb
    Aug 7, 2006
    170
    Many thanks
  6. rowlers
    rowlers
    Mar 2, 2005
    155
    16
    I can only reiterate...
    I got shot of my belkin cos I was sick of rebooting it daily!
    gone netgear and never had a problem since
  7. cjb
    cjb
    Aug 7, 2006
    170
    Anyone interested in a slightly used Belkin router. :D
  8. Bigpants2k
    Bigpants2k
    Jan 8, 2003
    216
    Bracknell
    +3
    Check to see if there is a firmware update for it
