Belkin PureAV HP for front's or rears.
Discussion in 'Cables & Switches' started by Dr E, Jan 23, 2008.
  1. Dr E
    Dr E
    Jan 16, 2008
    30
    I have two lots of different speaker wire for me to use.
    They are...
    Belkin PureAV 16 guage basic wire
    Belkin PureAV 16 guage Hi Performance wire
    I want to run wires in the ceiling to connect 2x rears and 2x fronts and of course the centre speaker.
    But I only have enough to do either the fronts or rears in the hi performance stuff.
    Question is whats best in hi performance wire is it the fronts or the rears.
    Tia
    Mick
  2. paulst10
    paulst10
    Dec 16, 2004
    12,805
    Essex
    +2,249
    Moved to Cables, Interconnects & Connections :smashin:
  3. indolent
    indolent
    Nov 7, 2005
    64
    +8
    Fronts every time. Very little comes out of the rears. 60% from the center, 30% from fronts and 10% from rears.
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If they are both 16 gauge I suspect you'll have trouble spotting any performance difference between them to be honest.
    If it worries you though then yes, the centre and fronts are the most important of the speakers.
  5. Dr E
    Dr E
    Jan 16, 2008
    30
    Thanks guys fronts it is.
