Belkin N router
wizzbizz
Hi all, need a bit of advice. I recently upgraded my router to a Belkin N router in order to avail of a good wireless system. However the wireless receptiopn would appear to be haphazard and at times very very poor. I am really disappointed with this as I was under the impression that these newer routers were a huge improvement on the older ones
Chris Muriel
They are only likely to be an improvement if all WLAN connected equipment is using wireless-N and all from the same manufacturer.
Have you run Netstumbler to check if there is interference from nearby wireless networks (eg. your neighbours) ?
A change of channel may get you clear of this.
Chris Muriel, Manchester
