D
Deleted member 173019
Hi Guys, its just possible you could save my life, my sanity and also my windows (since this damn router will be thrown through it any second).
Basically I own a Belkin F5D7632-4, have had it for many years, ticks all the boxes and does everything I want it to do, however, I have now purchased another Xbox that I want to use in another room, so I need a wireless access point, being that I have used Belkin products for many years and have always trusted them, I went out and purchased a F5D7230-4 wireless router that also has the ability to be used as a standalone access point, so far so good. Anyway, I have had the same wireless network for at least 3 4 years (when G was cutting edge & damned expensive), set it up myself and have used it on a daily basis, so I know the basic premise of setting up a Belkin wireless network.
I start up my new F5D7230-4 which I plan to use ONLY as a wireless access point, follow the instructions here:
http://belkin.httpsvc.vitalstreamcd...t/dl/using_f5d7230_router_as_access_point.pdf
To the word and NOTHING!!!!
I can still see my F5D7230-4, I can connect to it, but it seems to be totally separate to my original F5D7632-4 router, they have different SSIDs and are just shown as two networks, the newer one simply has no internet connectivity. I have set up both routers correctly, remembering to enable WDS on the original router, I have made sure theyre on the same channels (tried various), I have made sure the WEP code is the same (also tried removing ALL security), I have included the second routers IP address in the first IP address pool, also tried setting it outside this range, nothing .PS. MAC filtering is disabled, but Ive also tried putting it on in case, still nothing.
Anyone else been through this or have any advice, tips to offer?, I have trawled the internet and can only come up with people saying it is possible to use the F5D7230-4 as an access point, but no one mentioning any issues????.
HARDWARE INVOLVED:
Original Router
Belkin F5D7632-4 (Ver 4000uk)
Firmware Version - 4.01.09
Wireless Access Point
Belkin F5D7230-4 (Ver 7002uk)
Firmware Version - 9.01.10
Any ideas?, Im fresh out ..
Thanks in advance
HARDWARE INVOLVED:
Original Router
Thanks in advance
