Being back TV Swivel stand
readingfan
We don't all want a soundbar , but some of us do want to be able to change the location / direction of view of their TV
We are not all fortunate enough to be able to sit opposite our lovely screens and frequently like to watch from other locations
I have an L shaped lounge diner and this was never a problem with a Swivel stand
Furniture is usually 45cm deep , but with Feet being placed 80cm apart you can no longer angle a tv to suit any of our viewing preferences, thus preventing me and others like me buying the latest tech.
I don't want a wall bracket and never needed one but now it's a problem
LG , Sony, Panasonic , bring back this option , Please
EndlessWaves
Panasonic has, the EX750 has a swivel stand.
And there's nothing preventing you buying a third party floor, tabletop or wall stand that can swivel, the VESA mounting system for TVs is standardised and supported by just about everything.
paulyoung666
That's what I did because of the stupidly wide feet on the 55ks7000 !!
readingfan
If I could find something suitable I would have ! Cheeky!
Also I can only fit a 40-43" set so again , a bit of a struggle .
I'm not the only person who lives with limited space
There is nothing as neat or the right size to suit my living environment, so no a Swivel stand worked for me for the last 20 years , but is no longer an option.
This cannot be unique to me
Dodgexander
readingfan
I would be more concerned about the viewing angles of the TV vs a swivel stand.
I also echo what has already been said, the stand a TV has shouldn't be much of a factor of purchase any more when you can buy stands that fit any TV that swivel on eBay such as this: Tabletop Pedestal Bracket TV Stand LCD/LED 26 -47 Inch Swivel Height Adjustable
I'm delighted all these people intimately familiar with the layout of my home telling me what I do and don't need.
If I could find a suitable solution I wouldn't want the Swivel stand , but as long as your alright jack bugger what people like me want !
readingfan
I have purchased 2different versions of this but the Swivel is too far back on the Stand negating the ability to Swivel very much .
We used to be able to Swivel to the dining area I got area and tothe lounge area
This is no longer an option.
I guess I could buy 2 tv for the one room[emoji23]
EndlessWaves
If you're saying the issue was the stand's limitation then buy one that can swivel more than 15°. The first result from a quick search is this one which provides 120° of swivel, so they're definitely available.
It's not clear whether that's 120° each way or +- 60° but it's a lot more than 15°.
If you've got some sort of stand depth limitation and inability to use wall mounting them perhaps look into a mount that clamps onto the back edge of a desk or table. Some of the high end monitor ones should easily support the weight of a 40/43" TV.
readingfan
I do appreciate the various advice above , The problem with all conventional stands such as those suggested above have the pivot at the rear of the stand , thus up against the wall so you can't Swivel , the stand on my Samsung is in the centre of the base which permits the Swivel .
All my previous Swivel stand models were the same. As virtually all av furniture assumes you sit directly opposite without a central point of gravity , I cannot turn the tv without a leg falling off the unit or the tv hitting the wall , hence my desire to have a Swivel stand. I have a AVR and 5.1 speaker system so I don't need a soundbar space between the feet .
EndlessWaves
What's stopping you moving it away from the wall?
readingfan
My grandad actually made his own version of this for his old TV Big Screen TV Swivel: Amazon.co.uk: Electronics
Would that help at all with a centre stand?
Whats stopping you from wall mounting?
That looks really interesting and may work , I suspect that the position of the feet on a 40" screen may be more than 21" apart but I'm going to check , certainly could work with a centre stand I think.
My wife doesn't want to chase the wall or see the cables so a wall bracket is a last resort .
May still do it though but your Swivel base might be ideal .
Thank you
