behringer Feedback Destroyer...
Discussion in 'Home Cinema Speakers' started by jonnyv, Aug 4, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Can someone explain to me about the beringer feedback destroyer ?
    I was looking into using it with my sub woofer to give a flat frequency response.
    I remember reading a comprehensive artice here about these units, can anyone help ?
    cheers
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    thanks jase, thats the one.
    I am thinking about getting one of these units, what do you think ?
    cheers
  4. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    I was going to buy one myself but in then end did´nt bother as the sub response without one was pretty good. From what I gather you can trim out the peaks of the frequency response but can´t boost a dip (null). You´ll probably get more info out of forum member Ramius with regards to the pro´s & cons of having one.:)
  5. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Thanks for the reply jase, i must have too much spare time !
    Just looked back at the subwoofer measurements thread that started it all off,
    http://www.avforums.com/forums/showthread.php?s=&threadid=33958&highlight=subwoofer+measurements
    i posted various graphs there. Your help was very much apreciated. In the end i just stopped measuring,left the sub where it was.
    But now i have new frount and center speakers, and some spare cash , i was thinking...'maybe i can get it to sound even better ? '
    or maybe i should find something else to do !?
    could you take a look at the old thread jase and take a look at my graphs, Sub is still at top left of living room behind tv, and see if the feedback destroyer would benefit me ?
    cheers
  6. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    I´ve had a look and you´d be able to trim the response to some extent. I´d also consider adding a second sub to even out the bass response, put the money into that instead. Worth thinking about anyway.
    Also, it depends how it all sounds in the first place, playing about with the positioning etc could give you better results than the feedback destroyer pro. Who´s to say you´ll like the sound of a sub with a flat frequency response?? you might not!!:eek: :)
  7. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Hi jase, thanks again for the reply...
    Maybe i am reading too much into this subject.
    At the moment i think my setup sounds great, but was concerned about a flat frequency response.
    Maybe i shouldn't mess !
    cheers
  8. MikeK
    MikeK
    A hifi dealers dream - definitely the first symptoms of "upgraditis"
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Destroyer seems to work well, just bare in mind there is a processing delay. They are cheap however, especially when you consider what is in them.
  10. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Your right MikeK ! Ive had the disease for 5 years now, the doc says theres no cure !
  11. GaryG
    GaryG
  12. jonnyv
    jonnyv
    Mar 31, 2002
    2,152
    48
    +41
    Thanks for that link Gary, from what i read when i scanned through the numerous posts:
    It seems very complicated to set up.
    Even when setup to give a flat response, sound isnt that good ?
    I still am interested in getting one , but i probably need to hear one set up first, or get someone to set it up for me.
    Other wise i will probably stick with what ive got !
  13. GaryG
    GaryG
