Behold, I bring you good timings!
Discussion in 'Projectors, Screens & Video Processors' started by Barend, Jan 9, 2005.
  1. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Just finished tweaking my new toy- the Iscan HD+
    Finally managed to feed PAL 576p from my Denon 3910 to the dvi board of my Panny.
    Glad it does, because using ntsc 480p looked bad (while 540p was fine), something I fail to understand...
    For PAL 576p: Changed one of the many tweakings- HFRONT from 12 to 115, was all, took some time to get there with no pic...
    Brilliant and superclean picture now, worthwile improvement for both dvd and sat (yuv = component).
    Main difference vs yuv is the cleaner colors, not so much the sharpness which is also very good when analog out is selected.
    Again, ntsc 480p looked dreadful.
    Even my vcr shows a good picture now.
    Next I'll try to feed RGB from my SVHS recorder.
    What I love about this scaler is the tweakability and continuous pan & zoom buttons.
    Thought it should be possible to to call several user settings, like for zoom settings, anyone?
    What I don't like is the IR receiver which seems half blind, even standing in front I often must push several times for something to happen, even worse so with my Axim ccf based remote.
    My Axim works fine with all other kit, even on the difficult Panny plasma.
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Glad to hear you got it working but your thread title is just too corny...you should be ashamed of yourself :D and so should I for being geeky enough to get it :rotfl:
    Cheers, Lee
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    Good luck. Let us know if you manage it :devil:
    No analogue VCR of any type will output RGB. A VHS VCR will only output composite and an SVHS VCR will only output composite & S-Video.
    Mark.
  4. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    re the title, shocking.... anybody would think it was near christmas time....
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,664
    UK
    +115
    Cheers Barend...will give these settings a try when I do my DVI testing.
    How do you cope with R1 NTSC DVD's if you are outputting 576p?
    Did you try native res @ 852x480 (PLA1) and then frame convert, how did this compare to 576p?
    Did you try 720p-50 on the analogue conenctions as this is meant to be the best analogue output?
    I've always found IR on my iscan HD to be very sensitive and works perfectly with my pronto from about 10ft - maybe a different one in the HD+ ???
    JJ
    P.S. The cheesy title made me smile, but I'm geeky too :)
  6. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Thought it fitted because we have one very active member on the board called Messiah (double grin)
  7. Barend
    Barend
    Apr 12, 2004
    804
    +9
    No, SVHS has RGB out, it's in the standard, still wonder where I get the sync though.
    Someone else wrote one can use the composite wire for syncing, but where to connect the other end on PLAY ?
  8. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    Hi Barend,
    Have you played with H-Sync, V-Sync, H-Size and V-Size? I played with H_Sync and the pictures esp from SKY+ are great, much lesser jaggies than before. I also changed the H-Size and V-Size to something larger than my native resolution of 1024 by 768 to 1050 by 786 on my 42phd7 to get a bigger picture as otherwise I get some instability in geometry on SKY+ programmes as the pictures shifted a lot on H and V axes.
    Also, I find the DVDO HD+ (as I have one too) a bit too fluff. It should have included more details for people who want to play a bit deeper with it.
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,110
    Norwich
    +790
    Afraid it is not in the standard, where would it get the RGB from??
  10. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    I must confess I have only ever heard of 1 SVHS deck with RGB out many years ago, certainly none of my current or previous JVC decks have had it
    for a start, isn't one of the pins shared for RGB and Y/C
  11. Barend
    Barend
    Apr 12, 2004
    804
    +9
    My Denon 3910 is region free, that's not the problem, used to play anything on component, did not try now I found my hdmi bliss, will let ya know
    I did but untweaked I got no dvi pic nor yuv pic, will try now I know what to twiddle
    Yes it worked but no better than 540p-60 which gave the best image analog
    I found this on my Axim X3 (normally works up to 7m):
    ccf commands work well if they're preceded by some other command like the sound switching for DVD on my receiver, separated by 0.5s delay...very strange must give it a hard think...
    Agree orig remote is OK...
    DVDO has a IR protocol pdf, will try to grasp it...
    JJ
    P.S. The cheesy title made me smile, but I'm geeky too :)[/QUOTE]
  12. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Help, I'm new into this AV Stuff.
    I've bought a Denon DVD 3910 and connected it to a Screenplay 7200 via the 3910 HDMI out to the Screenplay DVI/HDMI input.
    Question. How do I configure this kit? 720, 1080, progressive or interlaced?
    I am predominantly watching R2 DVD's and some Imax DVD's
    I would really appreciate some expert advice as I find myself a little out of my depth. :rolleyes:
    I also bought the Denon AVR 3805.
    Also, is it best to go straight to the Projector from any DVD player or any benefits in going through the ciruitry in the 3805? I have a Panasonic E65 and want to connect to the projector so I can use the tuner?
    Advice would be most appreciated.
  13. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    +16
    You want to set the 3910 to output 720p and then set your PJ to dot-by-dot or through mode that way you are sending the PJ its native resolution and by-passing some of its processing with the superior processing of the 3910.
    Cheers, Lee
  14. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Thanks Lee, I also have the option to output via HDMI
    HDMI Y Cb C r
    HDMI RGB
    Which should I choose?
    Thanks again
