Beginners Question
Discussion in 'Plasma TVs Forum' started by loveleeds, Aug 11, 2005.
  1. loveleeds
    loveleeds
    I just bought an Aldi Tevion 42" plasma. I can hear the booing and hissing...but I'm happy with it for the price and the use it gets!!
    At the moment I am running my sky+ into my JVC home cinema system via a scart and then running the JVC system signal into the plasma via a scart.
    The only thing I have so far been disappointed with is the quality of sports pictures ie footie and cricket. Is there anyway to improve these pictures eg directly plug the sky+ into the RGB?? Or am I stuffed cos of the low screen res?
    Any advice for a complete beginner would be appreciated!!
  2. scarty16
    scarty16
    Jul 1, 2003
    1,406
    +304
    Define "quality" and then it may be more obvious what the potential problem is
  3. loveleeds
    loveleeds
    Ok....quality....hmmm...as players are running there seems a nasty pixelated quality to the crowd behind....the moving camera sweep type shots are the worst.
    Not a good description I know so apologies!!
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    It is called processing and it is one of the reasons people pay more for a differnt brand.
    Things to check, turn your Sky box picture settings to RGB and contrast low.
    Make sure you have turned off any processing off on the plasma itself, and make sure you have the contrast down to a resonable amount too.
    Is there a cinema, user or film mode under the picture settings?
    make sure it is on one of them and then put your contrast at 45% to start with.
    Adjust the brightness whilst playing a film with black bars and turn it down until it does not get any darker.
    And make sure the the colour looks natural, if you pump the colour up it will cause all sorts of problems to other areas.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Does it look like it is juddering across the screen rather than smooth as you would get on a CRT?
  6. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    When you mentioned the quality of the footy pictures I assumed it was because you were watching Leeds United on your plasma - obviously you wont be seeing very good quality images then!!!
    CK
  7. loveleeds
    loveleeds
    Yes that's a far better description!! :)
  8. loveleeds
    loveleeds
    Oi!! :mad: Below the belt!! :D
  9. Lionheart
    Lionheart
    One other thing LL..once you have adjusted all the settings give the tv time to run in...I found the picture improves ...I saw pixelation with my telewest box when I first got the tv but now a month later its almost impossible find
