beginners numpty question ?
tabs
numpty question part deux ...
is there a particular "optical lead" i should look for or are they all the same .. ie, connecting ends etc :confused:
i want to connect a ps3 to my amp (onkyo 505) .. i have connected the ps3 to the amp via HDMI then a HDMI lead to the tv
geomuss
just let the amp do the decoding of the audio! through the HDMI:thumbsup:
make sure the sound outputs on the ps3 are all correct
tabs
thanks geo ... but can you break it down into english for a non understanding newbie :(
are you saying i dont need an optical as sound should appear through the HDMI connection ?
geomuss
if i am right in understanding the amp, it will decode the HDMI sound information which you require, so your output from the amp will display the PS picture.
no need for optical, better sound quality from HDMI anyway!!
