Beginner
Discussion in 'Projectors, Screens & Video Processors' started by Itsshreck, Apr 14, 2016.
Tags:
  1. Itsshreck
    Itsshreck
    Apr 14, 2016
    Tyldesley
    hi thanks for letting me join
    I have a GEHA top vision portable projector
    And Iam having problems focusing the things I put on it I no how to use it but the problem I have is that Iam using it in a very limited space I no its not ideal and that if I move the projector or what Iam focusing on it would be fine but unfortunately I can't do this
    Now when I lift the acetate paper up I can focus it great
    So in a nutshell is there anything I can use to hold the acetate up at the correct level ?
    Sorry to waffle on
