Beginner Question (groooan - sorry!)
Discussion in 'Cables & Switches' started by j4m3s, May 13, 2005.
  1. j4m3s
    j4m3s
    Hello -
    Been hanging around reading this forum for a while - picked up some good advice - thanks!
    I have pretty basic requirements - just wondered if anyone can tell me if I am on the right lines here.
    I plan to connect my new LCD (LC265AGE) to my DVD-player/recorder (Panny DMR-E55) using component video + Stereo audio. I'll also just be passing normal UK terrestrial analogue signal though the DVD recorder to the LCD. Does that sound ok ? Or should I use SCART from my TV to DVD recorder.
    I really am sorry for this basic question as I am sure it has been asked a thousand times already.
    Thanks in advance !
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Component is generally regarded as being a better quality cable.On the other hand not knowing myself anything about dvd recorders,i dont know what signal is required to actually record picture+sound.Best consult your manual .
