Question Beginner JBL LSR305 MKII/F12/sound board setup help
Discussion in 'Home Cinema Speakers' started by Desertrat3511, Sep 4, 2018.
  1. Desertrat3511
    Desertrat3511
    Sep 4, 2018
    California/Colorado
    Hello total beginner here about to invest in my first nice set of speakers and sub. I am about to purchase the following setup and wanted to double check to see if there are better options or incompatibilities going on.
    I am going to be using a sound board to connect my laptop to two jbl 305 mkII and an American Bic F12 sub. The sound board and speakers are listed below. The plan is to connect the laptop to the sound board with a 3.5mm male to 2RCA then connect the sound board to the 305s with 2 1/4 TRS cable and the board to the F12 2 RCA to 1 RCA. Will this work? Am I dumb? Any suggestions?
    BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer
