Before I go mad ... .
monkeyleader
.... I want to create a water mark to apply to some of my exported images ... I'm creating the water mark in Photoshop Elements 6 and then applying this to exported images in Aperture 3 ..
Trouble is .... I always get the background text box in the water mark, rather than just the text itself ...
I'm sure its a very simply answer - click some random clicky box ... but it's doing my noggin in ...
Any pointers much appreciated.
thanks,
Nigel
ncmoody
I do not know the answer, however, I have found that Google can usually supply the answer in the form of a tutorial for all things Photoshop,
Good luck - it should only take 5 mins. or so to find something suitable.
Jammyb
Not sure, but is it because you're saving it as a jpeg or some other format that flattens the image onto a white background, try saving as a PSD or PNG or something.
achoudry
can't you set the canvas to be transparent in photoshop?
monkeyleader
Finally worked it out - a few pointers on here helped.
While all layers are active in PSE choose background eraser tool ... get rid of the background.
You can then save this as a .PSD file so the layers are still active ..
Once applied in Aperture I get only the writing ...
Madness averted !
