Beech Effect Bookshelfs
Discussion in 'Home Cinema Speakers' started by v1per, Apr 25, 2007.
  1. v1per
    v1per
    Dec 10, 2005
    72
    11
    Hi all,
    Was looking for some advice regarding a nice pair of bookshelfs, beech effect for my living room, ideally want some quality bass and punchy hi's. Just looking for opinions I have a price ranger upto about £150 for a pair but will happily go significantly higher if I find something really nice.
    Also, it's a light beech I'm looking for as I have the Ikea Oppli...
    [​IMG]
    Thanks in advance
  2. MickyBoy
    MickyBoy
    Nov 15, 2001
    114
    londinium
    +4
    I have the same stand (well... the Lack model which is just one shelf high instead of two) in the same colour and my Mordaunt Short 904 floorstanders in Maple go very well with it (almost spot-on colour match in fact). For bookshelf's you'd be looking at the 902's which I don't own so can't comment on their sound.
    M
  3. lelykins
    lelykins
    Tannoy F1 customs may suffice, i've heard more bass from other speakers but for around £100 not many better all round packages.
  4. v1per
    v1per
    Dec 10, 2005
    72
    11
    Thanks Micky/ Lelykins...
    ...I shall have a look based on your advice. Much appreciated.
    Micky, the Mordaunt 902's I found seem to be more pine looking the 'avant' series seems to be the beech one, would that be right as far as you're aware?
    Cheers again.
