techville
I am thinking of replacing an aging Samsung 43 inch plasma in the bedroom tv. Sources are Sky Q and Amazon Prime & Netflix from a Firestick. Dont really care for 4k, looking for a budget TV
The two main considerations are reasonable motion handling for football (Inherit benfit of plasma tv ?) and avoiding glare (inherit downside of plasma tvs?)
The tv is on the wall opposite the bed, so viewing angles don't matter, it will only ever be viewed straight on. There is a large window on the side and the glare is really quite bad. I don't want to sit in darkened room as often is the case.
Not sure on what type of panel I am looking for, even after reading the guide.
Any suggestions on panel type/tv s?
