bedroom replacement
Discussion in 'Plasma TVs Forum' started by MARTIN TURNER, Apr 19, 2004.
  1. MARTIN TURNER
    MARTIN TURNER
    my crt tv in the bedroom went bang sat. nite which gives me the ideal opportunity to replace it with a screen hanging on the wall. i will be able to run all the cables thru the wall behind the screen into a wardrobe where the power outlets are but have ltd space for media boxes ,sky boxes etc in the bedroom. i was thinking hitachi but wondered if anybody had any firm views on plasma vs lcd. also being totally useless diy'er anybody have any good ideas about cheapest suppliers and fitters in essex area.thx guys. martin.
  2. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hi from what i have read if you wont to go 37inch+ then you wont a plasma but if 37 is the top for size the lcd
  3. MARTIN TURNER
    MARTIN TURNER
    I have the room on the wall for 42" but i need an all in one solution picture,sound, etc.i also need to know if i can hide away my sky box in the wardrobe and somehow still use the remote. i have lots of wall space but no shelf room for big silver boxes. ta.
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,467
    Windsor
    +1,044
    I think the Hitachi has the remote receiver on the panel, which is then routed to the media box. so you could have the media box through in the next room no problem.
    There are also a few different ways of piping IR signals - check out the remote forum on here.
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    You can pipe IR signals to control kit in another location using IR remote extenders (I just happen to have a few for sale in the classifieds forum :) ).
    If you just want to control a Sky box and nothing else then a TV Link will probably be the easiest and neatest solution.
  6. MARTIN TURNER
    MARTIN TURNER
    Thx lads. if thats correct about the hitachi it looks like a deal breaker all i need now is the cheapest price and somebody to install it for me. any volunteers?
