Because 42PD5XXX Owners asked me to ......
Discussion in 'Plasma TVs Forum' started by dUnKle, Jul 7, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    14,918
    +2,056
    Well I have just done the latest calibration on the set and am more than happy
    That blurry, smeary, Solarization effect is now almost completly gone - even on problem channels such as BBC 1 and ITV things are fine - some grain but I put that down more to whats being broadcast (NYPD Blue on FX is one such problem)
    Settled on
    Picture Mode - Natural
    Contrast +5
    Brightness +5
    Colour -7
    Sharpness - 15
    Colour Temp Normal
    Contrast Mode Dynamic
    YNR Low
    CNR Low
    Film Mode On
    LTI Low
    CTI Middle
    Black Enhance Off
    Also lowered all RED and GREEN values for colours
    DVD is a different set of settings - ill post those once I am sure im happy there and calibrated those
  2. John
    John
    Dec 13, 2002
    11,194
    +2,828
    I'll give them a go , what did you lower the values to ? :thumbsup:
  3. dUnKle
    dUnKle
    Jan 1, 2001
    14,918
    +2,056
    lowered each by about 5 or 6 notches
    just watched last nights NYPD and even that looks good now
  4. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    Many thanks Duncan :smashin:
  5. dUnKle
    dUnKle
    Jan 1, 2001
    14,918
    +2,056
    Just interested if anyone has tried or improved on these settings
  6. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I'm not in front of my 5300 right now, but I can't recall seeing any color value settings? or color temp?
  7. siy
    siy
    hmmm - thats what I am trying to worrk out too!
  8. John
    John
    Dec 13, 2002
    11,194
    +2,828
    to get to the colour menus :lesson:
    press "menu"
    Select "picture"
    scroll down to "reset"
    then down again , next option should be YNR
    down past reset again and you should have three more options
    Colour temp
    Colour management
    colour decoding
    :smashin:
    Does the 5300 connect using the media box , as that might be why you can't see them
  9. siy
    siy
    Thanks - yes the 5300 does have the media box - do you think that means we cannot change the colour settings? I am not at home at the moment, so cannot check it.
  10. AngryofMayfair
    AngryofMayfair
    Yes that's the problem - the media box is the same as the one supplied for the previous (3000) series and so it won't have all the additional colour adjustments that are built in to the 5000 series.
    The model with the MM box also has a different remote - the one with no direct input buttons - you have to scroll up & down to select inputs. Unfortunately the direct select input buttons of the 5000 remote does not work with the MM box either...
