Question Beat value 4mm2 speaker cable out there?
technoholic
Hi all
I'm currently in the process of building an extension which has speakers in it right now, the cables go back to the rack. In the new room, the speakers will be in a totally different place, and I need to extend the existing wiring. Ideally I would run all new cables but I'm trying to keep the spiralling budgets as tight as possible. So I'd like to solder and heat shrink an extension on to each cable. Currently I'm using Van Damme blue 4mm2 but I've not seen the benefits of this so far. I'm going to stick with 4mm for the extension of these cables but for any new ones I will use 2.5. What is the best value 4mm cable I can use to extend the Van Damme? Is Fisual s flex still the best alternative? It's still not cheap but cheaper than Van Damme.
Also same goes for 2.5, what would you use?
edd666999
technoholic
I definitely need some length of 4mm van Damme blue to extend a run of VD Blue that I already have but I will probably take a look at that 2.5mm cable you suggested for a couple of new runs I need. Thanks
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
