Beastie Boys Anthology - Menu problems on Arcam DV88?
Discussion in 'Movie Forum' started by clived, Dec 11, 2002.
Tags:
  1. clived
    clived
    Jan 4, 2002
    268
    Hertfordshire
    +5
    Anyone experiencing problems on the "choose the video, choose the remix" portions of these discs? Works fine on my computer DVD player, but on my Arcam DV88 when you hit play having chosen the video and audio... nothing happens at all - just stays at the menu.. wierd!
    Clive
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    No... but it sounds like a quick call to arcam is in order.. are you on the latest software/firmware for the machine? if Not it may be sorted by them :)
    Matt
  3. rob_w
    rob_w
    I've got the R1 of the beasties' anthology(criterion) - if it's the same then I had some probs on my pc with the same bit - haven't tried it on my dvd player yet though...
    Rob
    ***just checked 4 tracks on disc 1 and they seem to be ok - tosh sd 220-E ***
  4. clived
    clived
    Jan 4, 2002
    268
    Hertfordshire
    +5
    Rob, have you tried it on your DVD player yet?
    Just tried it on my DV88 with the latest firmware sent out by Arcam last week... still doesn't work.
    Anyone else with a DV88 have this disc?
    Cheers, Clive
  5. rob_w
    rob_w
    Yep, I did check it (look at the bit I added to my post above - Its fine on my toshiba sd 220-E dvd player)
    It still wont work on my pc properly though:(
    Rob
  6. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,785
    EU
    +816
    A bit off topic, sorry :blush: but I was thinking of buying this DVD for the Sabotage video alone. Can anyone tell me what the 5.1 remixes are like and are many of the songs remixed.
    Cheers,
    RDB :)
  7. clived
    clived
    Jan 4, 2002
    268
    Hertfordshire
    +5
    RDB,
    Sabotage doesn't actually have any remixes - there are four video angles to chose from however!
    In general, I think the 5.1 mixes are fine - i.e. not too over the top!
    Of the 18 tracks, 11 have remixes and 8 have multiple video angles. Only 4 have neither.
    If you're a BB fan, you'll love this DVD whatever!
    HTH, Clive
  8. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,785
    EU
    +816
    Many thanks for the detailed reply.
    Will be buying it soon.
    RDB :)
  9. clived
    clived
    Jan 4, 2002
    268
    Hertfordshire
    +5
    RDB (or anyone else who has or is buying this title), if it works fine, could you let me know what DVD player you have - I'd like to know which machines have a "very sub standard navigation system" - see the e-mail from Arcam below!
    Cheers, Clive
    Dear Clive,
    Unfortunately there are certain disc's that cause problems for the DV88 and
    although the disc may play on other players that is irrelevant as they do
    not use the same system as our DVD players, 99% of the time the problem is
    the way the disc has been written and other DVD players use a very sub
    where as the DV88 uses a navigator that follows
    the DVD specification to the latter.
    Please send me the disc and I will be able to look into the problem, I will
    also be able to run the disc on our DVD tester which will allow me to view
    all the files on the disc. I am not saying that it definatly the disc but
    as long as you have software version 1.81 then you are up to date. Also I
    will try the disc on the new DV88 Plus to see if it will play on the new
    Mech that we use.
  10. clived
    clived
    Jan 4, 2002
    268
    Hertfordshire
    +5
    Well, seems the legendary Arcam customer service isn't going to come to my rescue on this one - they recognise there is a problem, but us existing customers just aren't as important as new ones, obviously!
