Beamax series A-wall mounting
Discussion in 'Projectors, Screens & Video Processors' started by crunchman, May 15, 2005.
  1. crunchman
    crunchman
    Jan 22, 2005
    730
    North Wales
    +61
    I have no idea how to fix this screen to the wall.
    Any ideas :lease:
  2. inzaman
    inzaman
    Dec 16, 2002
    7,885
    Derby
    +935
    There are proper mounting brackets for it, i am very surprised that you didnt get these with the screen as mine inlcuded these.
  3. crunchman
    crunchman
    Jan 22, 2005
    730
    North Wales
    +61
    I got this black hook type thing that can be fixed to the wall.
    But I dont think its strong enough to hold the screen
  4. inzaman
    inzaman
    Dec 16, 2002
    7,885
    Derby
    +935
    Did you get two of them?
  5. FoxyMulder
    FoxyMulder
    You could always do what i did and cut the screen out of the metal frame ( my wall has something like tiles in them and i couldn't wall mount it and ceiling was out of the question ) After i cut it out of the metal frame i hung it on the wall using the middle pull out bracket and i simply tacked it all down, mind you its now a home cinema room and no longer a living room.
  6. crunchman
    crunchman
    Jan 22, 2005
    730
    North Wales
    +61
    yes I did
  7. inzaman
    inzaman
    Dec 16, 2002
    7,885
    Derby
    +935
    If they are the metal hook things, and they also include the screws and fittings, that fit into the back of the screen border to hold it against or onto the wall then yes these are strong enough, they have been holding mine up for the past few weeks.
  8. crunchman
    crunchman
    Jan 22, 2005
    730
    North Wales
    +61
    Ohh cool thanks mate :thumbsup:
  9. outoftouch
    outoftouch
    Hey
    I got the Beqamax R series manual screen recently and it came with no fittings. I just drilled the plasterboard wall, inserted long, 1.5 inch wallplugs and used some long two-inch steel screws, leaving a little bit out to hook the eyehole on to. Just do one side, hook it on and then using a chair (or a mate) raise the other side of the screen up and use a spirit level along the top to ensure it's level. When correct, mark through the eye hole with a pencil, drill second hole, wallplug, screw and that's that. Steady as a rock.
  10. inzaman
    inzaman
    Dec 16, 2002
    7,885
    Derby
    +935
    That sounds that it does work well for the R Series but the A Series does not have any eyeholes. :)
  11. pmc
    pmc
    Oct 18, 2004
    1,411
    +109
    Believe it or not I fix my A-Series to the wall with BluTack! It rests on top of some shelves and I just blutack the top to the wall to stop it falling forward.
