Beamax Screen with IR and Harmony 1000... HELP
churchwa
I have a Beamax Screen with an IR remote. It works perfectly with the remote provided with the screen. However I cannot get it to work with the Harmony 1000.
I have tried it direct with the Harmonry remote and through the extenders and nothing works. It controles all my other devices without a problem.
I have even tried to teach the Harmony remote the raw codes from the screens remote but this did not work either.
Can anyone help?
PaulCarter
Are you using the Beamax IR remote box? I think their code is 10622. If so, I've got it working with the Harmony 1000 and the codes are in the Logitech online database so no clever programming.
However, finding the Beamax is a bit of a struggle - in the Add Device wizard choose "Home Automation -> Home Appliance" in the Device drop down and then Beamax under Manufacturer and 10622 as the Model number.
Bingo!
Hope that works for you too
Paul
p.s. What projector are you using?
