Beamax or DRH screen?
Discussion in 'Projectors, Screens & Video Processors' started by Lobo, Aug 10, 2005.
  1. Lobo
    Lobo
    Feb 4, 2004
    220
    +3
    Ive just bought myself an Optoma H78 projector and am now looking for a screen.
    The screen is to be eight foot wide and manual. I also need it custom made as I need a large drop due to a high ceiling.
    Ive narrowed it down to DRH screen vs Beamax. They are both of gain 1.
    However, the Beamax is coming in at approx £100 dearer.
    Does anyone think there will be a noticeable difference in picture quality between these 2 screens? If not, I will happily go for the DRH screen and put the £100 elsewhere.
    Otherwise, if the Beamax will provide a better picture I dont mind spending the extra money.
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    I would do a search for screen fabric, I cant remember the site name but they sell fabric for .57p a cm.in various widths. Its matte white 1.1gain so all you need is a frame and you can build any custom size you require.
  3. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
