yanglifeng
Beamax motorised projector screen help needed - help with making the screen work for 2015 tech!
I've put together a really slick projector set up and now need some advice on how to get the projector to close without the screen either rolling down too far or me having to manually press the button at the back to stop it - would be very grateful for any suggestions
What I'd like to achieve is:
1) Beamax screen fully closes without 'letting out' any of the screen - it currently shows 10cm or so of the screen
2) figure out a way to access the IR facilities which are built into this Beamax screen and teach my Peel Smart remote the codes so I can raise the screen up and down using the iOS iphone app 'SmartRemote' from Peel ( I have the device receiver)
I've attached a small video to show the problem and provided the manual the tech team from Beamax gave me - I can't seem to access both screws inside the casing as they are positioned in a way that makes access tough. Any suggestions on special hex keys would be great.
Please advise so I can bring my set up in line with 2015's newest tech
best,
David
Beamax projector | Facebook
best,
David
