Quantcast
Beamax M 10245 Electric Screen curl
Doctor Smith
I purchased the screen just before chrstmas and I have just got round to installing it.
I have noticed on both sides the screen is curling and it goes as far as the viewing area.
There are also some slight ripples in the middle.
I have left the screen down overnight and they are still there.
can this be caused by the screen not being perfectly level to the ceiling?
My old Beamax R was perfectly flat.
Member 518284
forget being level to the ceiling
the screen itself has to be perfectly level :smashin:
Otto
If getting the screen level doesn't sort out the problem, let me know and we'll replace your current screen with a new one.
Thanks,
otto
Doctor Smith
How can I level the screen? I though it would hang level anyway? Like a plumb rule
Doctor Smith
Thanks,
otto
Thanks, would it be a straight swap out?
Doctor Smith
Casing is now perfectly level and the edges still curl into the viewing area.
I have also notices a fault with the material. A two inch white patch. It is a different colour from the rest of the screen.
Doctor Smith
Otto when will you contact me about swapping the screen.
It's been nearly a week and I have heard nothing!
Member 518284
I agree with this, send Otto an email and he`ll respond
the forum isn`t really the place to conduct business
Doctor Smith
I have sent e mails to otto and Roy jowett. I reported it 2 weeks ago still nothing has been done
mathew
I hope you get it sorted soon.
I tried to buy one of Beamax's exdemo screens and they were a complete pain. Luckily I eventually got a refund and glad to be free from them so I can buy a screen from elsewhere.
Luckily you have Roy Jowett on your side so they should be doing the chasing?
Doctor Smith
New screen delivered today. Not had time to check it though, will be doing this at the weekend. The joy
