Be Warned
Discussion in 'Projectors, Screens & Video Processors' started by Ken, Jan 5, 2005.
  1. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    If you are planning on making a 4:3 screen into a 16:9 screen using fabric paint, beware.
    I did just that, it looks great, but the only problem is the paint will not go off; it has been ever so slightly tacky since Christmas eve.
    If anyone else has had any experience of this, how do you stop it from being tacky?
    I'm feeling a bit peed off, but it is my own fault.
    Ken
  2. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    What does it say on the tin? What paint is it you've used? Sounds as though it maybe oil based in which case it will take some time to cure. If it isn't and the instructions state it should be dry by now, I would contact the manufacturer and ask there opinion.
    Good luck :)
  3. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    It is a fabric paint and is water based but it doesn't seem to want to cure. The instructions are to use a hot iron but that's not practical.
    I know, stupid.
    I've email Dylon to see if they have any suggestions; if they can be bothered to reply, we'll see.
    Ken
  4. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    Mmm Water based should go off very quickly, whats the screen material made of you've painted it on to? Again I can't see that having a bearing though but you never know. Is the room where it is well ventilated ie not damp? Sorry just trying to cover some possible causes you may not have considered. :)
  5. Alaric
    Alaric
    Mar 12, 2001
    1,759
    Peterborough, Cambs, UK
    +149
    Hot iron - Hmm, would a low heat hair dryer be any better ???
    Though i'd watch for curl/shrinkage with any heat.
  6. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    I tried that, it didn't seem to make any difference.
    Ken
  7. jonny m
    jonny m
    Mar 22, 2002
    405
    Its the plastisers in the screen to keep it flexable apparently, the creator of goo said the same thing, you can't paint onto these screens as it will never dry.
  8. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    Thanks. I ended up dusting it down with talc; it isn't quite as black but when in movie mod you can't tell and I can now wind it up and down without it trying to stick.
    Ken
