be warned that darblet/ee comes with a USA 2 pin plug-bummer
gbmitie
For those thinking of buying the darblet/ee be warned it comes with ... yes a USA 2 pin plug and not your 2 pin shaver socket plug either, its those flat 2 pins on a moulded plug so it wont fit into a 2 pin to 3 pin adaptor. I thought it was illegal to sell such a plug in UK?
a bummer, as with the usa to uk travel adaptor plug it will stick out a mile.
gbmitie.
ps as you will see from the post below by Ricky I was misled, it looks as if it depends where you buy it from as Ricky sends his with a uk power supply which is the correct procedure.
Lee.Pie
Where did you buy yours from?
You should have been supplied a uk adaptor with it, so you don't even need to use the 2 pin plug.
Gordon @ Convergent AV
AVForums Sponsor
For those thinking of buying the darblet/ee be arned it comes with ... yes a USA 2 pin plug and not your 2 pin shaver socket plug either, its those flat 2 pins on a moulded plug so it wont fit into a 2 pin to 3 pin adaptor. I thought it was illegal to sell such a plug in UK?
gbmitie
it is illegal...if you sell goods in UK they must come with a UK plug
kbfern
Mine came with an adapter included.:)
gbmitie
I wont say where I bought it yet but where can I buy a UK adaptor so as to not have to use the usa 2 pin one stuck on a three pin adaptor? And How do I know it will be safe? It says +5v dc ON THE DARBEE but does that mean up to +5v dc or exactly +5dc. I have an 3 PIN UK plug adaptor but its rated to 5.3v dc!! Its used to charge a torch.
out of interest will this work with the darbee?
http://www.amazon.co.uk/Plug-Camera...22/ref=sr_1_16?ie=UTF8&qid=1345738712&sr=8-16
Here are 3 images that show how much that usa 2 pin/uk adaptor combination sticks out.
gb-
kbarnes70
AC to DC 5V 1A UK Plug CCD Camera Power Supply Adapter: Amazon.co.uk: Electronics
gb-
GB - you need to be totally sure that any adapter you use is the correct voltage, delivers the correct current (amps) and has the correct polarity on the mini-plug (2.1mm plug). If you use an incorrect adapter you may destroy the Darblet and this will void any refund you may want of course. Allan at IdealAV sells these and knows his stuff, so I would only use the one he recommends.
Cheers,
Keith
Rickyj at Kalibrate
AVForums Sponsor
gbmitie
Am I right in thinking this is the one you bought off the classifieds so any additional/replacement power supply provided by a retailer may have been omitted from the delivery?
kbarnes70
What additional or replacement power supply would that be? AFAIK all Darblet's come with a 100-240v 'wall wart' power supply with a US style 2-pin connection. All that is required is a cheap, readily-available US to UK adapter to plug the wall wart into (as in gbmitie's photos).
Rickyj at Kalibrate
AVForums Sponsor
Sorry Keith, it appeared that the posts above confirmed the units were shipping with replacement power supplies/adapters, and presumed the one gbmitie bought would do too. The adapter in gbmitie's picture could do the job, but gbmitie appeared to suggest all units only come with the 2 pin power supply which is not correct.
