be gentle - sky+ newbie question!
Discussion in 'Sky Digital TV Forum' started by chmaiden, Jun 26, 2005.
  1. chmaiden
    chmaiden
    Nov 10, 2003
    112
    16
    Hi all....just a simple q but as a newbie to sky+ i dont know the answer! having just upgraded to sky+ (and am pretty happy with it so far!) I obvioulsy have a spare digibox....now I'm pretty sure that it can be used for free to air (not freeview) ...is it just a case of coax cable from the socket? where do i get a box to send the cable? And do i need a new card (where do i get that from or should sky have given me another card?)
    thanks in advance!!!
    c :thumbsup:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You have two options really - connect a cable to one of the spare outputs on the dish (or pay an aerial installer to do this), and connect it to your old Sky box, and buy a free-to-air card from Sky for £20. Or you can ask Sky for "multi-room" for your old box, which will cost you £10 a month extra and you can receive all the channels that you receive on the Sky+ box on your old box too. All the details are on the Sky web site
