BD801s Memory Problem
Discussion in 'Projectors, Screens & Video Processors' started by cosmic023, Jul 29, 2004.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    Just need to clear up a problem i'm having......with my BD801s.
    After converting my DIY 4:3 screen into a 16:9 version, i had to do the anamorphic squeeze mod. Yeah that went ok for Pal & NTSC disks.
    Only had just found out about the twin memories function on each input, great feature and helps out for 16:9 & 4:3 setups. I'm sure i didn't see that in the manual ??
    Pal switching between 16:9 and 4:3 modes work OK, currently using [email protected] resolution.
    But the problem i'm having is the NTSC switching mode, seems to be sharing the same settings. Because when i switch between 16:9 and 4:3 modes they remain the same settings ?? Using a [email protected] resolution for NTSC disks.
    How do i solve this, i'm sure it's an easy solution ??
    Edit:
    Was a shared block causing the problem, everything is now ok !!
