BD 801s convergance turned off
Discussion in 'Projectors, Screens & Video Processors' started by supersub, Apr 24, 2005.
  1. supersub
    supersub
    Mar 14, 2004
    34
    Lincoln
    Hi all,
    it seems that the BD convergance has been turned off via the remote unit (when in service mode) and i can't seem to get it turned on again, also the set to mid position has been altered, (once again in the service mode)the picture was excellent until some one messed these settings up, any ideas how i turn them back on?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    "Convergence off" really is set to mid position for the convergece setting. There is no going back once the button is pressed. Same with what BArco calls mid position. (it will do the convergence too). It sets all the bella chips to 50%.
    There is no undo from these settings (the undo feature didn't come in for a few years after yopu machine).
    Your only hope is that you still have a good block left in the PJ. set say you midpositioned while displaying a PAL disk but still have not reset any thing on an NTSC setup on you machine.
    You can either delete the bad PAL block
    Or Copy the settings from the NTSC (good block) into your bad block.
    One you have mid positioned, time for a really strong coffe and knuckle down to setting up for scratch
  3. supersub
    supersub
    Mar 14, 2004
    34
    Lincoln
    Many thanks Roland,
    decided to service the pj copied a block accross used star wars THX to set it up from scratch, 4 hours later & several coffees every thing is ok.
