BD 800 converting from ceiling to table mount
Discussion in 'Projectors, Screens & Video Processors' started by Cam, Sep 29, 2003.
  1. Cam
    Cam
    I just bought a BD 800 that is set for front projection/ceiling mount that I want to change to front projection/table mount.
    I cannot seem to find the switches that I need to toggle to change the settings. Are they located under the black metal plate to the left of the chassis ?
    Cam
  2. flibble
    flibble
    Feb 21, 2003
    72
    Cam, you can find scanned PDFs of the 800's manuals here, I believe the Installation manual mentions the change needed.
    http://www.lynxxx.nl/barco/downloads/
    MAKE SURE you read the safety instructions very carefully, as there as some extremely high voltages inside the case.
    Peter
  3. Cam
    Cam
    Thanks once again Peter, thats a great site for BD800 info.
    The switches were under the black heatsink/guard and I managed to adjust them and the vertical scan switch after downloading the correct manual.
    Cam
