BD 701 service manual and G2 settings
Discussion in 'Projectors, Screens & Video Processors' started by bartp, Jan 15, 2005.
  1. bartp
    bartp
    Jan 10, 2005
    70
    Hi Guys,
    Anyone got the manual for 701 or can hep me setting g2 and focus on my pj?
    Many thanks
    Bart
  2. arbey
    arbey
    Oct 8, 2002
    76
    I'll give it a try! :)
    G2: go into 'service' menu and select 'G2adjustment'. Contrast/brightness will automatically be adjusted to make the raster (that's behind the image) visible.
    Now look into the tubes and observe the raster brightness while ABL is ON.
    Switching ABL off by pressing 'enter' should give you the same raster brightness...if not, adjust G2 for that particular tube untill raser brightness is the same for ABL on or off.
    Focus: choose 'random access' and choose 'color select', now put on sunglasses and look into the tube. Turn the focusknob for that tube so that focus is OK inside the tube. Adjust the focus with the lensknobs for best focus on screen.
    Be sure your barco is warmed up properly.
    Good luck!
