BD 701 Problem
Discussion in 'Projectors, Screens & Video Processors' started by bartp, Jan 10, 2005.
  1. bartp
    bartp
    Jan 10, 2005
    70
    Hi Guys!
    As you probably notice i am new to this forum. So... Hello to everyone!
    I've been searching around the crt market for a while and finally ended up with BD 701 for now. I am pretty on the top of the things but...
    I had no problem setting the pj up on the ceiling but can't get rid of a slight problem: my blue on green convergence is slightly out on the bottom of the screen in the middle. i am running it on HTPC 800x600@60Hz.
    Would appriciate if someone can help me finding source of the problem
    Regards,
    Bart
  2. arbey
    arbey
    Oct 8, 2002
    76
    Do you mean you cannot adjust when you're trying to do convergence from blue on green?
    When you're in 'random access', go into 'convergence adjustment', choose 'blue on green' and select the area that gives the problem...what numbervalue do you read? Can you adjust the position from the blue grid onto the green grid in this mode?
    regards
  3. bartp
    bartp
    Jan 10, 2005
    70
    well, i can adjust it, so the blue raster moves. it's perfect on the whole area apart from small part of the bottom centre. it is quite out. with blue raster movet max to the left. it's still out at the end of adjustment. Mechanical adjustment of the lenses is fine.
    bart
  4. arbey
    arbey
    Oct 8, 2002
    76
    Hi Bart,
    As you know, when doing convergence you have to choose a block and adjust it. One block influences another block. That's why you have to start convergence in the middle and then do the blocks around the mid block, like this you work from the inside towards the outside.
    In your case, maybe the blocks next to the mid/bottom block are set in extreme values and that could influence the fact you're not able to adjust that mid/bottom block.
    Maybe you could start with a set to midpoint and redo convergence.
    regards
  5. arbey
    arbey
    Oct 8, 2002
    76
    some questions:
    - did you check if the deflection yoke is firmly attached to the bell of the CRT?
    - did you turn any potmeter, like the one for Vertical Amplitude for blue?
    regards
  6. bartp
    bartp
    Jan 10, 2005
    70
    I've set everything to mid point and reconverged again with different resolutions and refresh rates. still no joy. Haven't changed any settings apart from electromagnetic focus and readjusted G2.
    Any ideas???
    Thanks,
    Bart
  7. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    Hi can you start with the problem you are having do you get c12 come up in the convergence block i have just set up my 701 and it look fine this is a easy projector to set up should be all set up in 1 hour
