Quantcast
BBC micro computer connecting to TV
Nesty1760
A friend given me a BBC micro computer from the 80's.
I want to test it the display, to see if it works.
Does anyone know what kind of lead I require to attach it to a TV?
Sonic67
With the UHF out:
RCA to TV aerial?
https://www.amazon.co.uk/CONNECT-Plug-Aerial-Lead-1-5M/dp/B0792G7X4V/ref=sr_1_6?ie=UTF8&qid=1517510705&sr=8-6&keywords=rca+to+aerial
https://www.amazon.co.uk/2pcs-Female-Adapter-Coaxial-Connector/dp/B00UBYPQGI/ref=sr_1_14?ie=UTF8&qid=1517510705&sr=8-14&keywords=rca+to+aerial
Then after that an aerial cable to go to the female on the adaptor.
The Video Out looks like a BNC socket. From that you should get composite out.
https://www.amazon.co.uk/DELOCK-Cable-BNC-Male-RCA/dp/B00E5FQS52/ref=sr_1_16?ie=UTF8&qid=1517510936&sr=8-16&keywords=bnc+component+cable
Though you'd need a phono composite input on your TV.
We need photos of your TV and the BBC or model numbers etc.
Nesty1760
Thanks for the reply. I think I might have one of those connectors laying around.
I am not interested in picture quality. Just want to see if a picture does get displayed via the cheapest option!
Nesty1760
Cheers will do. TBH I am wishing, I never turned the thing on, as it's got a right pungent smell coming off it!
Mr Quint
In all honesty I'm not 100% sure, but you could locate the screws on the bottom and try removing a few of them to see if the case comes apart. I'd guess there could be quite a lot of dust inside and that's maybe what smells.
tich77
In which case, donate to my good home for old computers.... ;)
Seriously, if you decide you don't want it, there is a healthy 8bit hardware market.
Nesty1760
Ok thanks. I'll have a look inside. Though I am of the reckoning. My BBC, don't look like that on the inside! :(
Trending threads
