BBC iPlayer v1.6 stopped working on 5530
m.stephens
Established Member
Anyone following the long running saga of the 5530 and BBC iPlayer will know that the old v1.6 standalone app worked for TV streaming only whereas v2.5 which works on a 5800 doesn't work at all on a 5530.
Well things seem to have changed yet again and v1.6 doesn't work either now that the BBC has gone for their integrated player.
Going to the http://www.bbc.co.uk/mobile/iplayer will simply give you a "not supported" message.
On the plus side you can listen to radio by going to the http://www.bbc.co.uk/iplayer site and selecting the radio program you want. Doing the same with a TV program just gives you a white rectangle where the picture should be (and no sound).
Has anyone had any success with hacking the 5530 web browser so it tells the bbc you've got a 5800 ?
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
