D
Deleted member 275754
Hello, Iplayer / PC boffins, please help.
I'm trying to get my dad's PC back able to play Iplayer. It used to then suddenly stopped. These days all users have to sign in to the BBC before playing anything, which shouldn't be a problem, but there is some kind of connection issue with the BBC. Its the computer's fault. I have gone through various steps and this much I know but I am stumped as to the reason.
Its a Windows 7 PC, up to date. IE11 is used and up to date. Kaspersky Internet Security is used. Its virus free and also a Malwarebtyes check has been done. BT fibre and the Homehub 5.
I'll list the steps and eliminations I've thus far passed.
- His account exists.
I know this because I have signed in as him at my place several times, on a system also based on Win7, IE11, Kaspersky, etc.
- Something at least is being received by the BBC.
When I deliberately use a wrong password it immediately flags it up as wrong - and this is on his machine. So it seems it is sending something but some aspect of software or a setting is preventing completion. When I enter the right password it doesn't connect though, it just hangs and hangs and hangs. On the BBC home page or the Iplayer home page there is the sign in button, which takes you to the account.bbc page for signing it. That page is actually unreliable in appearing ( not sure if that's relevant ) but when it does there are the fields to enter email and password, as you'd expect, but as I say when you sign in on his machine it just hangs and hangs.
- Some things I've tried :
Tried Kaspersky off.
Lowered security and privacy settings on IE11, to below my levels.
Cleared cache and cookies.
Reset his browser.
Got a fresh install of Adobe Flash ( not that I know this is part of things any more )
Updated Windows again.
Wondered about Java, or rather today "Java Runtime Environment" JRE and installed that.
( my own machine doesn't have that showing so is possibly a red herring )
In IE11 settings, have enabled active scripting and Active X controls and other similar sounding items.
Reset his router ( BT HomeHub 5 ) both by external button and by last resort recessed pin button.
I've checked for blocked lists, untrusted lists and the like in both IE and the Kaspersky.
He can sign in to things like Amazon and Netflix perfectly okay.
Hmmm.
So what could it be that the BBC site uses/needs that Is causing the failure to fully connect through ?
I've gone through the above and my own settings are more or less the same as his and my machine doesn't have a problem.
So can anyone suggest, what software ( or lack of ) or settings on his machine might be preventing the handshake fully happening ?
Weird, isn't it ?
This problem has already cause me quite a number of wasted hours wrestling with it, so I'd really appreciate any help.
Oh btw, the BBC seem rather aloof and unhelpful i.e nothing really set up by way of a help line / chat service. Moreover their standard advice just puts you round in a loop.
It wouldn't be BT would it , like perhaps not wanting people to strain their bandwidth with the likes of Iplayer ( surely not, as he gets into Netflix )
Cheers !
Reset his browser.
Hmmm.
Weird, isn't it ?
Cheers !
