BBC Channels unwatchable
Discussion in 'Satellite TV, Sky TV & FreeSat' started by fazer600, Nov 19, 2004.
  1. fazer600
    fazer600
    May 10, 2003
    28
    3
    Caterham, Surrey
    +5
    For the last couple of days the main BBC channels on my sky+ have become unwatchable. It's like the signal quality has completely deteriorated, the picture is either constantly breaking up or does not show at all(blue screen).
    All the other channels are fine and the other regional BBC channels seem to work fine (I get BBC London).
    What could cause just the loss of these channels (BBC1,2,3 & 4) :rolleyes:
    David
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Broadcast problems at source, uplinking issues or transponder failure.
    Problems with your own hardware, LNB high/low band and H/V switching, tuner issues or local interfernce from radar detector/wireless products.
    Hard to say really, worth doing a full check of all the channels and seeing if there is a pattern beyond the name, you don't say if you have access to just the FTA/FTV channels or subscription channels as well.
    Anyhow, full transponder list here.
  3. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    Whilst flicking through last night (friday) the picture quality on bbc1 did seem noticeably poorer than it normally is. This is in the south region btw.
  4. fazer600
    fazer600
    May 10, 2003
    28
    3
    Caterham, Surrey
    +5
    Looking at the lyngsat site, it appears to be just those channels on transponder 45 that are effected.
    I'll try plugging in my old sky digital box in later to see if it is doing the same.
    David
  5. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    I have had similar problems with my channels in the last week or so.
    Swapped digibox over to old one & still problems! :-(
