BB 8900 "Initialisation Failed Message"
Discussion in 'Mobile Phones Forum' started by Nash__, Jan 6, 2012.
Tags:
  1. Nash__
    Nash__
    Sep 9, 2005
    2,079
    Just in Wales
    +138
    Hi folks as title can this displayed message be fixed? It's running on Vodafone and is locked. When I put the sim in, all of a sudden I got this message for no reason completely out of the blue :confused:
  2. fizl
    fizl
    Apr 21, 2006
    2,163
    Not in London
    +460
    Some advice on blackberry forum is to try and re-install the base software, if that doesn't fix it, and if you still get the error message if you try another vodafone sim, you may need to get it repaired
  3. Nash__
    Nash__
    Sep 9, 2005
    2,079
    Just in Wales
    +138
    Hi thanks, base software would that be via BB Desktop Software?
  4. Nash__
    Nash__
    Sep 9, 2005
    2,079
    Just in Wales
    +138
    cheers mate sorted reset to factory defaults via the desktop software and now works again :thumbsup:
