battlefield 3 (simultaneous mouse AND joypad)
amkhan
right, fired up BF3 for the first time last night and got my arse handed to me very quickly.
I've come from console BF3 and this was painful (literately). The keyboard side was the problem for me, so I was wondering if its possible some how to use the joypad for movement (with thumbstick) and the mouse for looking/aiming?. Seems like that would be the perfect combo for me.
Left hand on joypad would give walk/run, plus two triggers and the dpad, so thats 8 (directions) and 6 buttons with the left hand, and the mouse for the rest. Is this possible?, keyboard was giving me finger cramps :thumbsdow
Cha1ky
How would you be pressing the x,y buttons etc on the right of side of the pad (reload etc)?
Can't see that working well at all.
Just stick at the pad if your happy using that. It will take you a while to adjust to keyboard and mouse.
amkhan
I got loads of "buttons" available to do stuff on the joypad (its a xbox one), the left side has a thumbstick for movement and also its a button (iirc this is used to crouch on the xbox). In addition to that there is left shoulder and left trigger buttons as well as 4 buttons on the dpad. so thumbstick + 7 buttons (inc 1 thumbstick button when pressed down). do i need more than 7 buttons?. Two buttons on mouse too of course (Actually got 2 extra shoulder buttons on microsoft 7000 series mouse, so 4 buttons there too).
What I'm after is the mouse for aim/looking and the left side of a joystick for everything else.
Cha1ky
Do you have extra buttons on your mousepad you can bind to things like reload, disarm etc? Theres 6 buttons on the right side of the pad so thats what you need to sort out.
You can play pad and keyboard at the same time btw.
amkhan
Yep the mouse (its a 6000 not 7000) has 4 buttons in total, two "normal" mouse buttons and two extra shoulder buttons which microsoft call rear and front buttons.
danz1985
Have you looked at the Logitech G13 or the Belkin or Razer equivalent?
There is a thumb stick for movement on there that you could use plus access to other buttons. Great piece of kit and would recommend one.
However if others say you can use a combo between the pad and mouse and you're happy with that then go for it. :thumbsup:
amkhan
I've not looked at the G13, just spent everything I had on a updated video card ;)
I really like the joypad on the xbox, and am OK with it on BF3 on 360, but first game on PC and fingers were hurting in 15 mins. I can play for hours on xbox without issue.
The reason for wanting to use a mouse rather than only a joypad is that on PC it seems, joypad vs keyboard+mouse = death every time for joypad user. I'm trying to use the best of both, so quick aim with a mouse, and joypad for movement etc.
stument
Stick to the keyboard and mouse within a month of playing you'll be use to it also play single player
Join noob servers where the ranks are not above 20 or something and you'll pick up how to play with out super ranked players killing you constantly
Then once more comfortable join normal servers
amkhan
Thanks all, will seek out some noob servers... now to get head round the mess that is the front end (origin?) to BF3. Wish it was all in game like on xbox, cleaner GUI IMO.
majnu
Stick to the Keyboard and Mouse and just practise. Playing on the controller is painful (I've tried it).
I invested in a decent mouse (Logitech G700) and with that I can:
1. Switch to Weapon 1 (Primary Weapon inc Vehcile)
2. Switch to Weapon 2 (Secondary Weapon inc Vehcile)
3. Deploy Weapon 3 (eg/ Med Packs)
4. Deploy Weapon 4 (eg/ Defibs)
5. Throw Grenades
6. Mele
7. Reload
8. Prone
I then use the keyboard for WASD; crouching and jumping movements.
If that doesn't work then there is their are devices like the fragfx and aimon (although I've never tried them myself so don't know how well they are or compatible.)
Cha1ky
You wont lose every time to a K/M player. I only use a pad (have no intention of spending ages getting better at K/M) and do ok.
Cha1ky
amkhan said:
sweet... might give the pad a bash then, perhaps its just the purists who bash the pads
You will lose out to good K/M players ( even K/M lose out to them too lol) but keep at it and adjust your sensitivity to suit. Just like on a console you'll have good games and bad games. As long as your enjoying playing and your comfortable with your control method then who cares otherwise :)
amkhan
Your K/D is not too bad i see too... I suppose its also a massive advantage using helicopters and jets
stument
Haha you'll loose badly to them though it's a shame you don't try to get better with K/M mate
Cha1ky
I wouldn't worry too much about K/D mate. Good objective players can have a poor one just for simply playing the objective. While doush bags who ignore everything boost their K/D's.
Mine was averaging around 1.1 until I started recording videos though lol.
Cha1ky
Na don't lose badly. Just lose to the faster aim adjustment. I realise that and live with it.
Tbh I wanted to make an effort to get better at it but I can only take so many deaths from looking at pressing the wrong button before I smash it. So I stick with what I know and I'm happy with.
Thinking I need to start another montage soon though.........
stument
Haha I get what you mean it's funny watching my dad play... Pressing all the wrong keys raging at nading himself
amkhan
this was me last night, imagine twister, only with fingers and and a keyboard... I think i may have broken a finger or two... :rotfl:
majnu
To be fair those hot pineapples in BF3 are deceiving, you can't tell if they are going to land at you or in another room half the time. :laugh:
The pads come into their own when flying helis or jets though, I wouldn't want to use anything else.
Don't you use the Onza Chalky? Pressing and holding the stick to sprint is less painful compared to the xbox controller because it uses some kind of special switch iirc.
Cha1ky
Yeah I do mate.
Don't find probs with the 360 controller though so not affected by that.
Neorion
Im with the op, I have come from BF3 on the 360 and have found it really difficult to switch.
I need to spend some time with my Logi G5 and change the buttons as suggested.
Flying is just wierd but maybe thats the lack of feedback for me? Although I can see helos being a lot easier.
Shows just how good this game really is when I have bought it twice, premium twice just to get onto the bigger maps.
Using Tanks and AA is a lot quicker with a K/M and I am a tank whore.
Tall_Paul
If you're gonna play BF3 on the PC, you need to play it properly. :smashin: That's keyboard & mouse.
Progression - TallPaul_S - Battlelog / Battlefield 3
BF3 was my first proper shooter on the PC after years of console gaming, for the first 30-50 hours my aim horrendous (13% accuracy, 0.8 KD, 300 SPM) and i would always have to be looking down at the keyboard to see what button to press, or putting my fingers on ESDF and wondering why I wasn't moving forward, or trying to go prone and just standing there like a noob :laugh::laugh:
Now though, keyboard is almost 2nd nature, I have a few buttons mapped to my mouse (toggle secondary/primary, toggle gadget 2 (defibs) & throw nade).
It'll be hard at first but just practice and it'll come. Said this many many times before but it's all muscle memory - do something enough times and eventually you'll be able to do it without thinking :smashin:
TBH, even if you were a pc gamer of 5 years, your first game of BF3 on the PC after playing on console you'd get owned, it's a very different game to console. Big, big tip - stay away from 64p servers - I did this and I played so much better, on a 64p server there's so much going on and the gameplay is really fast, whereas on a 32 map server things are much slower and you're not being shot at by 16 different enemies every time you spawn!
Also, not every game supports the game pad, what happens when you get a bit bored of BF3 and want to play another FPS, if it doesn't support the gamepad and you're not used to the keyboard, you're screwed.
eiren
Yeah don't be tempted to give in easily. Stick with keyboard and mouse and you'll be doing mid-air headshots in no time.
Delvey
Keyboard and mouse is better. I sometimes use a joypad for the game if i get cramp. I always use a pad for jets and helis
Similar threads
Trending threads
Latest News
John Williams' iconic movie themes get Dolby Atmos treatment
  • By Andy Bassett
  • Published
NAD launches T 758 V3i surround sound receiver
  • By Andy Bassett
  • Published
Sky unveils next tranche of HDR content
  • By Andy Bassett
  • Published
Acoustic Energy launches AE520 flagship speakers
  • By Andy Bassett
  • Published
Disney drops all 20th Century Fox branding
  • By Andy Bassett
  • Published
