battery rechargers
Discussion in 'Home Cinema Control & Remote Controls' started by njiri, May 23, 2003.
  1. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    Does Anyone know whether my UK battery charger will work in the USA?
    It is a 230v input, 250mA output, so will it just take twice as long to charge my batteries? or will it simply not work at all.
    Ta for anyone's help.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Depends on the power circuitry... in any case it wouldn't hurt to try as the voltage is lower there. It will either work or it won't.
  3. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    Thanks rct.
    I did take it, and it did work.
    saved me a fortune on batteries for my son's gameboy. I suppose I could have bought one out there, as they were pretty cheap.
