Battery pack for the DS Lite?
drunkenmaster
I'm going on holiday soon and just bought a DS Lite.
Iwas wondering if there was a battery pack add on in case i cannot recharge the DS.
If so where would be the best place to buy from - Im going in 10 days!!!
Conn
Not seen one.
If it helps, you should be able to pick up a USB charger (eBay)
alchemystical
Which obscure, untouched by modern man and isolated from the world place are you going to take your DS to then?
Let us know if there's a Nintendo Wifi spot there :rotfl:
Ol!ver
Plenty of places on ebay from the UK, most very respectable with shed loads of feedback. You'll get a USB charger from there for a fe bob. Think GAME had some for a fiver come to think of it.
Similar threads
